ratler's avatar
ratler
R7960P ReadyShare
I want to setup ReadyShare on my Nighthawk R7960P router.  I have a USB stick plugged in but that doesn't seem to work.  Does the device have to be a USB disk drive?  If so can it be EITHER a mechanical drive (heads, platters, all that) OR can it be a HDD?
  • michaelkenward's avatar
    michaelkenward
    It can be many tnings, but you don't tell us what you are using, so who knows?
    The manual spells out some of the requirements.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the section in the manual USB Device Requirements.
    You may have done that already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
    You can get an idea of what you can use from this page:
    Will my USB drive work with ReadySHARE | Answer | NETGEAR Support
    For serious networking use Ethernet.
    • ratler's avatar
      ratler
      Well, actually I said I was using a USB stick so you do know something.....  And it does NOT require any software to be downloaded to use it.  But it's a SanDisk USB 3.0 Ultra Fit flash drive.
      But thanks for the response with the link about disk drives.
        michaelkenward
        And the size is?
        You may think that saying "USB stick" reveals all, but in reality or is next to useless as a guide to what ReadySHARE can handle.
        Most USB will work, but anything that requires drivers and/or special software, for encryption for example, can cause problems. That applies regardless of the form factor.
        But if you don't want to explain what you are doing, and with what, that's fine by me.
