JohnRocha
Oct 10, 2016Follower
R8000 - Nighthawk X6—AC3200 Tri-Band WiFi Gigabit Router wireless extenders
I have a little bit of a challenge. What wireless extender can I use if my signal is a little weak and can I use this router for gaming using steam. I want to avoid wired network externders if poss...
- Oct 13, 2016
Hi,
You may check the link below for list of extenders you can use. The router will work with the steam.
http://www.netgear.com/home/products/networking/wifi-range-extenders/
JamesGL
Community Team
JamesGL
Oct 16, 2016NETGEAR Employee Retired
Hi JohnRocha,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
