Boubousse
Jun 26, 2017Tutor
R8000 and laserjet 1200
hi,
May I connect my laserjet on my router r8000?
i have plug it in usb on my r8000 but i can't see my printer.
i want use my printer without power on my computer, with another device .
Is it possible ?
Many thanks
Best regards
Hi Boubousse,
Check this KB article.
https://kb.netgear.com/19593/ReadySHARE-printer-set-up-instructions
You have to install ReadyShare print utility for it to work.
- JamesGLNETGEAR Employee Retired
Hi Boubousse,
Hi,
Many thanks, i try it quickly.
Best regards
I tried, the printer is connected in USB on the router but the pc must be switched on so that I can see the printer on my iPad. But I want to print from my iPad without switching on the pc.
many thanks
best regards
