teddy_c's avatar
teddy_c
R8000 can only get full speed if I factory reset it, but it only lasts for few minutes.
My broadband plan is 1Gbps and I use R8000.
I did a factory reset.
Then I plugged in the ethernet cable and did Speed Test , at beginning I can get 950Mbps, but a few minutes later I can only get about 300Mbps-400Mbps.
My pc was the only device that connected to R8000
Firmware version: V1.0.4.68_10.1.75
Does anyone know how to solve?
Thanks.
  • plemans's avatar
    how are you speedtesting?
    Using the built in app?
    Using speedtest through the browser?
    what device are you testing on?
    What modem are you using?
    • teddy_c's avatar
      teddy_c
       - speedtest app and speedtest website, they all give the same speed around 300-400Mbps
       - the built in speedtest also gives the same speed.
       - Mac OS
       - ISP provided ONU
