hparegger
Sep 04, 2016Follower
Bridge Mode with wlan
Hello Is it somehow possible to configure the R7000 in bridge mode (2.4ghz) and then use the 5ghz wlan to connect devices wireless instead of wired to the r7000? Mine shows "wlan off" if in bridge ...
- Sep 05, 2016
Hi hparegger,
For bridge mode, you can only use the router's LAN connection since the wireless is used to connect from the main router. You may try wireless repeating function.
JamesGL
Community Team
JamesGL
Sep 05, 2016NETGEAR Employee Retired
Hi hparegger,
JamesGL
Community Team
