rorton's avatar
rorton
R8000 firmware upgrade
The latest R8000 firmware upgrade states that iTunes Server is not supported. How does that affect iTunes?
  • No, it usually hosts on the pc/laptop its installed on. Unless you specifically set it up for a server to run on the router
  • plemans's avatar
    if your not using itunes server off the router, it doesn't.
    If you are, then don't upgrade.
    • rorton's avatar
      rorton
      Hi plemans,
      I use iTunes for backing up/syncing my iPhone. Does iTunes use the iTunes server on the router?
      • plemans's avatar
