cat139lyleb
Mar 17, 2018Aspirant
R8000 Firmware
Firmware - V1.0.4.12_10.1.46 I have no idea why itself firmware causing from between 526Mbps - 468Mbps to 17Mbps - 13Mbps... I had to rebooted and seem not good after that... 186Mbps, 168Mbps, 16...
cat139lyleb
Mar 23, 2018Aspirant
"dnsmasq-2.79" for DD-WRT
Let me do reflash Netgear's firmware (newest update) standby...
IrvSp
Mar 24, 2018Master
cat139lylebwrote:"dnsmasq-2.79" for DD-WRT
Interesting, that one was release on Mar. 18, 2018. Seems DD-WRT keeps current. Unless one could get a build from NG with this level of code in it there is no way that I can see to determine if this is the problem or not? Reasoning is that many have no problem? I don't think the DNS would have anything to do with the speed of the service, type of connection, nor the other settings in the router? However a test build would put this to rest. Wonder if JamesGL could make this happen as a beta? If nothing more maybe he or ChristineT could check with engineering and find out why it never has been changed?
