yashi
Oct 10, 2015Tutor
R8000 Half-Gigabit Speed
I have Gigabit internet which, when connecting my computer directly to the modem, I'm getting this speed: http://www.speedtest.net/result/4733704668.png whereas when the R8000 is in between I'm get...
TheEther
Oct 10, 2015Guru
He's getting 500+ Mbps through the R8000, so the link speed is certainly 1000 Mbps. That's not the issue.
Some features may impose a major performance penalty on the router. These can include QoS, Port Forwarding, Block Sites, and Block Services. I recently read that PPPoE can cause a drop like this. This is not surprising because the router's CPU has to get involved in the packet processing chain.
I would recommend resetting back to factory settings and perform a speed test. Hopefully, you will see full Gigabit speeds. Then, selectly re-enable features one by one until you see the speed drop. That'll be the culprit.
yashi
Oct 10, 2015Tutor
Thanks for your help.
I tried your suggestion: I reset the router back to factory settings, and the ONLY thing I changed after the reset was to change the MAC address of the router because my ISP is tied to the MAC address of my Desktop computer. I hope this does not affect performance.
Anyways, after the reset the problem persists:
With R8000 in between I'm getting:
http://www.speedtest.net/result/4734308361.png
With the modem directly to the desktop:
- TheEtherOct 10, 2015Guru
I don't know if MAC cloning will affect performance. According to this review, the R8000 should be able to hit 800 Mbps in the downstream direction.
- yashiOct 11, 2015Tutor
Apparently the MAC cloning was the culprit:
http://www.speedtest.net/result/4735880085.png
I worked on the problem hard all yesterday trying to tweak things and even tried DD-WRT. But nothing worked. I gave up yesterday and just went to bed, apparently I gave up exactly after leaving the router in default factory settings, without even doing the MAC cloning to make the internet work. Overnight, the ISP somehow gave a new lease on the router's default MAC address, and when I woke up there was internet available. Low and behold, I test the speed and it reaches even 940Mbits/s, just as when the modem is connected directly to the computer.
Thanks TheEther
