yashi
Oct 10, 2015Tutor
R8000 Half-Gigabit Speed
I have Gigabit internet which, when connecting my computer directly to the modem, I'm getting this speed: http://www.speedtest.net/result/4733704668.png whereas when the R8000 is in between I'm get...
yashi
Oct 10, 2015Tutor
Thanks for your help.
I tried your suggestion: I reset the router back to factory settings, and the ONLY thing I changed after the reset was to change the MAC address of the router because my ISP is tied to the MAC address of my Desktop computer. I hope this does not affect performance.
Anyways, after the reset the problem persists:
With R8000 in between I'm getting:
http://www.speedtest.net/result/4734308361.png
With the modem directly to the desktop:
