Alvim
May 21, 2017Aspirant
R8000 Incredible in the beginning, completely disappointing 4 months later
Hello. I'm about to buy a R8000 however I really resistant due to Amazon reviews. Have Netgear fixed issued.by customer below? "When I first hooked up this router I was frankly surprised at how we...
- May 22, 2017that makes sense Mike!
from the 1 star reviews I read any of.them had issue resolved.
Anyway..I going to buy r8000 and look for additional warranty
thank you !!!
PSUGuitarist
May 24, 2017Star
I've recently had issues with this router - bought it back in November 2016. Both 5 GHz bands now get less than 1 Mbps, but the 2.4 GHz band will get around 20-30 Mbps. I can restart the router and the 5 GHz bands will work for a few hours, then drop the speed again. I've tried multiple versions of the firmware with no luck. I also attempted to contact customer support, but since I was past the 90 day customer support, they told me I would have to purchase a premium support package, which is ridiculous since this router cost $260 in the first place.
May 24, 2017Guru - Experienced User
What is the ISP mode Mfr and model#?
Any other wifi neighbors or electronics near by?
What channels are you using?
Try UpTo 300Mb on 5Ghz.
Try WPA2 and AES only.
Disable IPv6.
