thebassy
Nov 07, 2018Aspirant
R8000 Nighthawk Not Capable of 1Gbps WAN
So I've been doing some digging and found that the R8000 Netgear Nighthawk supports 1Gbps on the WAN port but the problem when you use the Router with PPPoE, CTF is disabled and/or the CPU cannot kee...
- Nov 09, 2018Netgear you legends..
Firmware update 1.0.4.28 - https://kb.netgear.com/000060364/R8000-Firmware-Version-1-0-4-28
Released a couple days ago fixes the WAN issue with 1Gbps internet connections. Now getting: http://www.speedtest.net/result/7784395149
Just in time too, as I bricked my ISPs modem đ
Thanks for this update guys!!
thebassy
I should of mentioned... I was on the latest firmware and was reverting to an old firmware to see if I could avoid the CFT/NAT Accelleration being disable when using PPPoE.
thebassy
Nov 09, 2018Aspirant
