kwzrex
Jan 11, 2017Aspirant
R8000 Nighthawk security upgrade
I finally got round to this upgrade. After downloading and unzipping the file, logging on over ethernet, Advanced/Admin/Router update, browse the file, the progress bar disappears after a few second...
- Jan 13, 2017
Hi kwzrex,
Reset the router first before loading the firmware. Make sure to use wired connection while loading.
JamesGL
Jan 13, 2017NETGEAR Employee Retired
Hi kwzrex,
