VU 582354
1 TopicR8000 Nighthawk security upgrade
I finally got round to this upgrade. After downloading and unzipping the file, logging on over ethernet, Advanced/Admin/Router update, browse the file, the progress bar disappears after a few seconds after the % gets to 100, and the router chugs along with no amber lights. I reboot everything works fine, but the firmware is at V1.0.0.102. Check for upgrades with the router and it says I have the latest firmware. Repeated the process three times now with the same result. Any ideas?Solved3.3KViews0likes3Comments
