kwzrex's avatar
kwzrex
R8000 Nighthawk security upgrade
I finally got round to this upgrade.  After downloading and unzipping the file, logging on over ethernet, Advanced/Admin/Router update, browse the file, the progress bar disappears after a few seconds after the % gets to 100, and the router chugs along with no amber lights.  I reboot everything works fine, but the firmware is at V1.0.0.102.  Check for upgrades with the router and it says I have the latest firmware.
Repeated the process three times now with the same result.
Any ideas?
  • Hi kwzrex,
    Reset the router first before loading the firmware. Make sure to use wired connection while loading.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi kwzrex,
  • JamesGL's avatar
    JamesGL
    Hi kwzrex,
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
    • kwzrex's avatar
      kwzrex
      Sorry for the delay, I travel for work, so haven't been home to give it a try.  The reset before reflashing worked and I was able to get the security update done.
      Thanks for the help!
