kwzrex
Jan 11, 2017Aspirant
R8000 Nighthawk security upgrade
I finally got round to this upgrade. After downloading and unzipping the file, logging on over ethernet, Advanced/Admin/Router update, browse the file, the progress bar disappears after a few second...
- Jan 13, 2017
Hi kwzrex,
Reset the router first before loading the firmware. Make sure to use wired connection while loading.
JamesGL
Jan 16, 2017NETGEAR Employee Retired
Hi kwzrex,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- kwzrexJan 19, 2017Aspirant
Sorry for the delay, I travel for work, so haven't been home to give it a try. The reset before reflashing worked and I was able to get the security update done.
Thanks for the help!
