jagdecat
Jun 22, 2018Follower
R8000 not providing WiFi. Lights blinking.
Had a power surge which knocked my router out. When it came back there's no WIFI and only lights blinking in sequence from orange to whites at bottom then to all then orange. Factory reset don't he...
- Jun 27, 2018
Hi jagdecat,
Welcome to NETGEAR Community! Here's a reference link to resolve this kind of scenario
How to resolve amber LEDs or a blinking power LED on NETGEAR routers
Blanca
Community Team
Blanca_O
Jun 27, 2018NETGEAR Employee Retired
Hi jagdecat,
Blanca
Community Team
antinode
Jun 27, 2018Guru
> [...] Here's a reference link to resolve this kind of scenario [...]
In which there's a link to a particularly old KB article (19841).
Also, on a Mac, the ping command suggested there will run forever (or
until manually interrupted, typically by Ctrl/C). For behavior similar
to that on Windows, use a command like the following:
ping -c 4 192.168.1.1
See also:
https://community.netgear.com/t5/x/x/m-p/1533866#M87578
