ThePie's avatar
ThePie
R8000 Open VPN Drops Internet Upon Connecting
I have a R8000 router and sometimes when I go to connect using the Open VPN connection it will show as connected but I won't have any internet access anymore. My connection log is below. The XXX is where my external IP address is for the router.
I have the service type set to UDP port 12970. Firmware version: V1.0.3.4_1.1.2
Log will be in the next post as there is a 20,000 character limit.
  • Actually I found a way around the issue. If you change the protocol from UDP to TCP everything works fine. Not sure what the issue is with UDP though.
  • Fri Feb 19 22:00:12 2016 us=21161 Current Parameter Settings:
    Fri Feb 19 22:00:12 2016 us=22161 config = 'client1.ovpn'
    Fri Feb 19 22:00:12 2016 us=22161 mode = 0
    Fri Feb 19 22:00:12 2016 us=22161 show_ciphers = DISABLED
    Fri Feb 19 22:00:12 2016 us=22161 show_digests = DISABLED
    Fri Feb 19 22:00:12 2016 us=22161 show_engines = DISABLED
    Fri Feb 19 22:00:12 2016 us=22161 genkey = DISABLED
    Fri Feb 19 22:00:12 2016 us=22161 key_pass_file = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22161 show_tls_ciphers = DISABLED
    Fri Feb 19 22:00:12 2016 us=22161 Connection profiles [default]:
    Fri Feb 19 22:00:12 2016 us=22161 proto = udp
    Fri Feb 19 22:00:12 2016 us=22161 local = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22161 local_port = 0
    Fri Feb 19 22:00:12 2016 us=22161 remote = 'YYY.mynetgear.com'
    Fri Feb 19 22:00:12 2016 us=22161 remote_port = 12970
    Fri Feb 19 22:00:12 2016 us=22161 remote_float = DISABLED
    Fri Feb 19 22:00:12 2016 us=22161 bind_defined = DISABLED
    Fri Feb 19 22:00:12 2016 us=22161 bind_local = DISABLED
    Fri Feb 19 22:00:12 2016 us=22161 connect_retry_seconds = 5
    Fri Feb 19 22:00:12 2016 us=22161 connect_timeout = 10
    Fri Feb 19 22:00:12 2016 us=22161 connect_retry_max = 0
    Fri Feb 19 22:00:12 2016 us=22161 socks_proxy_server = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22161 socks_proxy_port = 0
    Fri Feb 19 22:00:12 2016 us=22161 socks_proxy_retry = DISABLED
    Fri Feb 19 22:00:12 2016 us=22161 tun_mtu = 1500
    Fri Feb 19 22:00:12 2016 us=22161 tun_mtu_defined = ENABLED
    Fri Feb 19 22:00:12 2016 us=22161 link_mtu = 1500
    Fri Feb 19 22:00:12 2016 us=22161 link_mtu_defined = DISABLED
    Fri Feb 19 22:00:12 2016 us=22161 tun_mtu_extra = 32
    Fri Feb 19 22:00:12 2016 us=22663 tun_mtu_extra_defined = ENABLED
    Fri Feb 19 22:00:12 2016 us=22663 mtu_discover_type = -1
    Fri Feb 19 22:00:12 2016 us=22663 fragment = 0
    Fri Feb 19 22:00:12 2016 us=22663 mssfix = 1450
    Fri Feb 19 22:00:12 2016 us=22663 explicit_exit_notification = 0
    Fri Feb 19 22:00:12 2016 us=22663 Connection profiles END
    Fri Feb 19 22:00:12 2016 us=22663 remote_random = DISABLED
    Fri Feb 19 22:00:12 2016 us=22663 ipchange = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22663 dev = 'tap'
    Fri Feb 19 22:00:12 2016 us=22663 dev_type = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22663 dev_node = 'NETGEAR-VPN'
    Fri Feb 19 22:00:12 2016 us=22663 lladdr = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22663 topology = 1
    Fri Feb 19 22:00:12 2016 us=22663 tun_ipv6 = DISABLED
    Fri Feb 19 22:00:12 2016 us=22663 ifconfig_local = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22663 ifconfig_remote_netmask = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22663 ifconfig_noexec = DISABLED
    Fri Feb 19 22:00:12 2016 us=22663 ifconfig_nowarn = DISABLED
    Fri Feb 19 22:00:12 2016 us=22663 ifconfig_ipv6_local = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22663 ifconfig_ipv6_netbits = 0
    Fri Feb 19 22:00:12 2016 us=22663 ifconfig_ipv6_remote = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22663 shaper = 0
    Fri Feb 19 22:00:12 2016 us=22663 mtu_test = 0
    Fri Feb 19 22:00:12 2016 us=22663 mlock = DISABLED
    Fri Feb 19 22:00:12 2016 us=22663 keepalive_ping = 0
    Fri Feb 19 22:00:12 2016 us=22663 keepalive_timeout = 0
    Fri Feb 19 22:00:12 2016 us=22663 inactivity_timeout = 0
    Fri Feb 19 22:00:12 2016 us=22663 ping_send_timeout = 0
    Fri Feb 19 22:00:12 2016 us=22663 ping_rec_timeout = 0
    Fri Feb 19 22:00:12 2016 us=22663 ping_rec_timeout_action = 0
    Fri Feb 19 22:00:12 2016 us=22663 ping_timer_remote = DISABLED
    Fri Feb 19 22:00:12 2016 us=22663 remap_sigusr1 = 0
    Fri Feb 19 22:00:12 2016 us=22663 persist_tun = ENABLED
    Fri Feb 19 22:00:12 2016 us=22663 persist_local_ip = DISABLED
    Fri Feb 19 22:00:12 2016 us=22663 persist_remote_ip = DISABLED
    Fri Feb 19 22:00:12 2016 us=22663 persist_key = ENABLED
    Fri Feb 19 22:00:12 2016 us=22663 passtos = DISABLED
    Fri Feb 19 22:00:12 2016 us=22663 resolve_retry_seconds = 1000000000
    Fri Feb 19 22:00:12 2016 us=22663 username = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22663 groupname = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22663 chroot_dir = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22663 cd_dir = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22663 writepid = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=22663 up_script = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23164 down_script = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23164 down_pre = DISABLED
    Fri Feb 19 22:00:12 2016 us=23164 up_restart = DISABLED
    Fri Feb 19 22:00:12 2016 us=23164 up_delay = DISABLED
    Fri Feb 19 22:00:12 2016 us=23164 daemon = DISABLED
    Fri Feb 19 22:00:12 2016 us=23164 inetd = 0
    Fri Feb 19 22:00:12 2016 us=23164 log = ENABLED
    Fri Feb 19 22:00:12 2016 us=23164 suppress_timestamps = DISABLED
    Fri Feb 19 22:00:12 2016 us=23164 nice = 0
    Fri Feb 19 22:00:12 2016 us=23164 verbosity = 5
    Fri Feb 19 22:00:12 2016 us=23164 mute = 0
    Fri Feb 19 22:00:12 2016 us=23164 gremlin = 0
    Fri Feb 19 22:00:12 2016 us=23164 status_file = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23164 status_file_version = 1
    Fri Feb 19 22:00:12 2016 us=23164 status_file_update_freq = 60
    Fri Feb 19 22:00:12 2016 us=23164 occ = ENABLED
    Fri Feb 19 22:00:12 2016 us=23164 rcvbuf = 0
    Fri Feb 19 22:00:12 2016 us=23164 sndbuf = 0
    Fri Feb 19 22:00:12 2016 us=23164 sockflags = 0
    Fri Feb 19 22:00:12 2016 us=23164 fast_io = DISABLED
    Fri Feb 19 22:00:12 2016 us=23164 lzo = 7
    Fri Feb 19 22:00:12 2016 us=23164 route_script = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23164 route_default_gateway = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23164 route_default_metric = 0
    Fri Feb 19 22:00:12 2016 us=23164 route_noexec = DISABLED
    Fri Feb 19 22:00:12 2016 us=23164 route_delay = 5
    Fri Feb 19 22:00:12 2016 us=23164 route_delay_window = 30
    Fri Feb 19 22:00:12 2016 us=23164 route_delay_defined = ENABLED
    Fri Feb 19 22:00:12 2016 us=23164 route_nopull = DISABLED
    Fri Feb 19 22:00:12 2016 us=23164 route_gateway_via_dhcp = DISABLED
    Fri Feb 19 22:00:12 2016 us=23164 max_routes = 100
    Fri Feb 19 22:00:12 2016 us=23164 allow_pull_fqdn = DISABLED
    Fri Feb 19 22:00:12 2016 us=23164 management_addr = '127.0.0.1'
    Fri Feb 19 22:00:12 2016 us=23164 management_port = 25340
    Fri Feb 19 22:00:12 2016 us=23164 management_user_pass = 'stdin'
    Fri Feb 19 22:00:12 2016 us=23164 management_log_history_cache = 250
    Fri Feb 19 22:00:12 2016 us=23164 management_echo_buffer_size = 100
    Fri Feb 19 22:00:12 2016 us=23164 management_write_peer_info_file = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23164 management_client_user = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23164 management_client_group = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23164 management_flags = 6
    Fri Feb 19 22:00:12 2016 us=23164 shared_secret_file = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23164 key_direction = 0
    Fri Feb 19 22:00:12 2016 us=23164 ciphername_defined = ENABLED
    Fri Feb 19 22:00:12 2016 us=23164 ciphername = 'AES-128-CBC'
    Fri Feb 19 22:00:12 2016 us=23665 authname_defined = ENABLED
    Fri Feb 19 22:00:12 2016 us=23665 authname = 'SHA1'
    Fri Feb 19 22:00:12 2016 us=23665 prng_hash = 'SHA1'
    Fri Feb 19 22:00:12 2016 us=23665 prng_nonce_secret_len = 16
    Fri Feb 19 22:00:12 2016 us=23665 keysize = 0
    Fri Feb 19 22:00:12 2016 us=23665 engine = DISABLED
    Fri Feb 19 22:00:12 2016 us=23665 replay = ENABLED
    Fri Feb 19 22:00:12 2016 us=23665 mute_replay_warnings = DISABLED
    Fri Feb 19 22:00:12 2016 us=23665 replay_window = 64
    Fri Feb 19 22:00:12 2016 us=23665 replay_time = 15
    Fri Feb 19 22:00:12 2016 us=23665 packet_id_file = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23665 use_iv = ENABLED
    Fri Feb 19 22:00:12 2016 us=23665 test_crypto = DISABLED
    Fri Feb 19 22:00:12 2016 us=23665 tls_server = DISABLED
    Fri Feb 19 22:00:12 2016 us=23665 tls_client = ENABLED
    Fri Feb 19 22:00:12 2016 us=23665 key_method = 2
    Fri Feb 19 22:00:12 2016 us=23665 ca_file = 'ca.crt'
    Fri Feb 19 22:00:12 2016 us=23665 ca_path = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23665 dh_file = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23665 cert_file = 'client.crt'
    Fri Feb 19 22:00:12 2016 us=23665 extra_certs_file = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23665 priv_key_file = 'client.key'
    Fri Feb 19 22:00:12 2016 us=23665 pkcs12_file = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23665 cryptoapi_cert = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23665 cipher_list = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23665 tls_verify = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23665 tls_export_cert = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23665 verify_x509_type = 0
    Fri Feb 19 22:00:12 2016 us=23665 verify_x509_name = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23665 crl_file = '[UNDEF]'
    Fri Feb 19 22:00:12 2016 us=23665 ns_cert_type = 0
    Fri Feb 19 22:00:12 2016 us=23665 remote_cert_ku[i] = 0
    • ThePie's avatar
      ThePie
      Second Half
      Fri Feb 19 22:00:12 2016 us=23665 remote_cert_eku = '[UNDEF]'
      Fri Feb 19 22:00:12 2016 us=24165 ssl_flags = 0
      Fri Feb 19 22:00:12 2016 us=24165 tls_timeout = 2
      Fri Feb 19 22:00:12 2016 us=24165 renegotiate_bytes = 0
      Fri Feb 19 22:00:12 2016 us=24165 renegotiate_packets = 0
      Fri Feb 19 22:00:12 2016 us=24165 renegotiate_seconds = 3600
      Fri Feb 19 22:00:12 2016 us=24165 handshake_window = 60
      Fri Feb 19 22:00:12 2016 us=24165 transition_window = 3600
      Fri Feb 19 22:00:12 2016 us=24165 single_session = DISABLED
      Fri Feb 19 22:00:12 2016 us=24165 push_peer_info = DISABLED
      Fri Feb 19 22:00:12 2016 us=24165 tls_exit = DISABLED
      Fri Feb 19 22:00:12 2016 us=24165 tls_auth_file = '[UNDEF]'
      Fri Feb 19 22:00:12 2016 us=24165 pkcs11_protected_authentication = DISABLED
      Fri Feb 19 22:00:12 2016 us=24165 pkcs11_private_mode = 00000000
      Fri Feb 19 22:00:12 2016 us=24665 pkcs11_cert_private = DISABLED
      Fri Feb 19 22:00:12 2016 us=24665 pkcs11_pin_cache_period = -1
      Fri Feb 19 22:00:12 2016 us=24665 pkcs11_id = '[UNDEF]'
      Fri Feb 19 22:00:12 2016 us=24665 pkcs11_id_management = DISABLED
      Fri Feb 19 22:00:12 2016 us=24665 server_network = 0.0.0.0
      Fri Feb 19 22:00:12 2016 us=24665 server_netmask = 0.0.0.0
      Fri Feb 19 22:00:12 2016 us=26665 server_network_ipv6 = ::
      Fri Feb 19 22:00:12 2016 us=26665 server_netbits_ipv6 = 0
      Fri Feb 19 22:00:12 2016 us=27165 server_bridge_ip = 0.0.0.0
      Fri Feb 19 22:00:12 2016 us=27165 server_bridge_netmask = 0.0.0.0
      Fri Feb 19 22:00:12 2016 us=27165 server_bridge_pool_start = 0.0.0.0
      Fri Feb 19 22:00:12 2016 us=27165 server_bridge_pool_end = 0.0.0.0
      Fri Feb 19 22:00:12 2016 us=27165 ifconfig_pool_defined = DISABLED
      Fri Feb 19 22:00:12 2016 us=27165 ifconfig_pool_start = 0.0.0.0
      Fri Feb 19 22:00:12 2016 us=27165 ifconfig_pool_end = 0.0.0.0
      Fri Feb 19 22:00:12 2016 us=27165 ifconfig_pool_netmask = 0.0.0.0
      Fri Feb 19 22:00:12 2016 us=27165 ifconfig_pool_persist_filename = '[UNDEF]'
      Fri Feb 19 22:00:12 2016 us=27165 ifconfig_pool_persist_refresh_freq = 600
      Fri Feb 19 22:00:12 2016 us=27165 ifconfig_ipv6_pool_defined = DISABLED
      Fri Feb 19 22:00:12 2016 us=27165 ifconfig_ipv6_pool_base = ::
      Fri Feb 19 22:00:12 2016 us=27165 ifconfig_ipv6_pool_netbits = 0
      Fri Feb 19 22:00:12 2016 us=27165 n_bcast_buf = 256
      Fri Feb 19 22:00:12 2016 us=27165 tcp_queue_limit = 64
      Fri Feb 19 22:00:12 2016 us=27165 real_hash_size = 256
      Fri Feb 19 22:00:12 2016 us=27165 virtual_hash_size = 256
      Fri Feb 19 22:00:12 2016 us=27165 client_connect_script = '[UNDEF]'
      Fri Feb 19 22:00:12 2016 us=27165 learn_address_script = '[UNDEF]'
      Fri Feb 19 22:00:12 2016 us=27165 client_disconnect_script = '[UNDEF]'
      Fri Feb 19 22:00:12 2016 us=27165 client_config_dir = '[UNDEF]'
      Fri Feb 19 22:00:12 2016 us=27165 ccd_exclusive = DISABLED
      Fri Feb 19 22:00:12 2016 us=27165 tmp_dir = 'C:\Users\XXX\AppData\Local\Temp\'
      Fri Feb 19 22:00:12 2016 us=27165 push_ifconfig_defined = DISABLED
      Fri Feb 19 22:00:12 2016 us=27165 push_ifconfig_local = 0.0.0.0
      Fri Feb 19 22:00:12 2016 us=27165 push_ifconfig_remote_netmask = 0.0.0.0
      Fri Feb 19 22:00:12 2016 us=27165 push_ifconfig_ipv6_defined = DISABLED
      Fri Feb 19 22:00:12 2016 us=27165 push_ifconfig_ipv6_local = ::/0
      Fri Feb 19 22:00:12 2016 us=27165 push_ifconfig_ipv6_remote = ::
      Fri Feb 19 22:00:12 2016 us=27165 enable_c2c = DISABLED
      Fri Feb 19 22:00:12 2016 us=27165 duplicate_cn = DISABLED
      Fri Feb 19 22:00:12 2016 us=27165 cf_max = 0
      Fri Feb 19 22:00:12 2016 us=27165 cf_per = 0
      Fri Feb 19 22:00:12 2016 us=27165 max_clients = 1024
      Fri Feb 19 22:00:12 2016 us=27165 max_routes_per_client = 256
      Fri Feb 19 22:00:12 2016 us=27165 auth_user_pass_verify_script = '[UNDEF]'
      Fri Feb 19 22:00:12 2016 us=27666 auth_user_pass_verify_script_via_file = DISABLED
      Fri Feb 19 22:00:12 2016 us=27666 client = ENABLED
      Fri Feb 19 22:00:12 2016 us=27666 pull = ENABLED
      Fri Feb 19 22:00:12 2016 us=27666 auth_user_pass_file = '[UNDEF]'
      Fri Feb 19 22:00:12 2016 us=27666 show_net_up = DISABLED
      Fri Feb 19 22:00:12 2016 us=27666 route_method = 0
      Fri Feb 19 22:00:12 2016 us=27666 block_outside_dns = DISABLED
      Fri Feb 19 22:00:12 2016 us=27666 ip_win32_defined = DISABLED
      Fri Feb 19 22:00:12 2016 us=27666 ip_win32_type = 3
      Fri Feb 19 22:00:12 2016 us=27666 dhcp_masq_offset = 0
      Fri Feb 19 22:00:12 2016 us=27666 dhcp_lease_time = 31536000
      Fri Feb 19 22:00:12 2016 us=27666 tap_sleep = 0
      Fri Feb 19 22:00:12 2016 us=27666 dhcp_options = DISABLED
      Fri Feb 19 22:00:12 2016 us=27666 dhcp_renew = DISABLED
      Fri Feb 19 22:00:12 2016 us=27666 dhcp_pre_release = DISABLED
      Fri Feb 19 22:00:12 2016 us=27666 dhcp_release = DISABLED
      Fri Feb 19 22:00:12 2016 us=27666 domain = '[UNDEF]'
      Fri Feb 19 22:00:12 2016 us=27666 netbios_scope = '[UNDEF]'
      Fri Feb 19 22:00:12 2016 us=27666 netbios_node_type = 0
      Fri Feb 19 22:00:12 2016 us=27666 disable_nbt = DISABLED
      Fri Feb 19 22:00:12 2016 us=27666 OpenVPN 2.3.10 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on Feb 1 2016
      Fri Feb 19 22:00:12 2016 us=27666 Windows version 6.2 (Windows 8 or greater)
      Fri Feb 19 22:00:12 2016 us=27666 library versions: OpenSSL 1.0.1r 28 Jan 2016, LZO 2.09
      Enter Management Password:
      Fri Feb 19 22:00:12 2016 us=28166 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
      Fri Feb 19 22:00:12 2016 us=28166 Need hold release from management interface, waiting...
      Fri Feb 19 22:00:12 2016 us=506318 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
      Fri Feb 19 22:00:12 2016 us=608663 MANAGEMENT: CMD 'state on'
      Fri Feb 19 22:00:12 2016 us=609673 MANAGEMENT: CMD 'log all on'
      Fri Feb 19 22:00:12 2016 us=773750 MANAGEMENT: CMD 'hold off'
      Fri Feb 19 22:00:12 2016 us=776252 MANAGEMENT: CMD 'hold release'
      Fri Feb 19 22:00:12 2016 us=777753 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
      Fri Feb 19 22:00:12 2016 us=922944 LZO compression initialized
      Fri Feb 19 22:00:12 2016 us=923944 Control Channel MTU parms [ L:1590 D:1212 EF:38 EB:0 ET:0 EL:3 ]
      Fri Feb 19 22:00:12 2016 us=923944 Socket Buffers: R=[65536->65536] S=[65536->65536]
      Fri Feb 19 22:00:12 2016 us=923944 MANAGEMENT: >STATE:1455937212,RESOLVE,,,
      Fri Feb 19 22:00:12 2016 us=938808 Data Channel MTU parms [ L:1590 D:1450 EF:58 EB:143 ET:32 EL:3 AF:3/1 ]
      Fri Feb 19 22:00:12 2016 us=938808 Local Options String: 'V4,dev-type tap,link-mtu 1590,tun-mtu 1532,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client'
      Fri Feb 19 22:00:12 2016 us=938808 Expected Remote Options String: 'V4,dev-type tap,link-mtu 1590,tun-mtu 1532,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-server'
      Fri Feb 19 22:00:12 2016 us=939309 Local Options hash (VER=V4): 'b498be7c'
      Fri Feb 19 22:00:12 2016 us=939309 Expected Remote Options hash (VER=V4): '26e19fc0'
      Fri Feb 19 22:00:12 2016 us=939309 UDPv4 link local: [undef]
      Fri Feb 19 22:00:12 2016 us=939309 UDPv4 link remote: [AF_INET]XXXExternalIPXXX:12970
      Fri Feb 19 22:00:12 2016 us=939309 MANAGEMENT: >STATE:1455937212,WAIT,,,
      Fri Feb 19 22:00:12 2016 us=959482 MANAGEMENT: >STATE:1455937212,AUTH,,,
      Fri Feb 19 22:00:12 2016 us=959983 TLS: Initial packet from [AF_INET]XXX:12970, sid=9a5547fb ce87dc28
      Fri Feb 19 22:00:13 2016 us=86658 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, emailAddress=mail@netgear.com
      Fri Feb 19 22:00:13 2016 us=87448 VERIFY OK: depth=0, C=TW, ST=TW, O=netgear, OU=netgear, CN=netgear, emailAddress=mail@netgear.com
      Fri Feb 19 22:00:13 2016 us=184190 Data Channel Encrypt: Cipher 'AES-128-CBC' initialized with 128 bit key
      Fri Feb 19 22:00:13 2016 us=184190 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
      Fri Feb 19 22:00:13 2016 us=184190 Data Channel Decrypt: Cipher 'AES-128-CBC' initialized with 128 bit key
      Fri Feb 19 22:00:13 2016 us=184190 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
      Fri Feb 19 22:00:13 2016 us=184690 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
      Fri Feb 19 22:00:13 2016 us=184690 [netgear] Peer Connection Initiated with [AF_INET]XXX:12970
      Fri Feb 19 22:00:14 2016 us=947107 MANAGEMENT: >STATE:1455937214,GET_CONFIG,,,
      Fri Feb 19 22:00:15 2016 us=947967 SENT CONTROL [netgear]: 'PUSH_REQUEST' (status=1)
      Fri Feb 19 22:00:15 2016 us=967487 PUSH: Received control message: 'PUSH_REPLY,route 192.168.1.1 255.255.255.0,route-delay 5,redirect-gateway def1,route-gateway dhcp,ping 10,ping-restart 120'
      Fri Feb 19 22:00:15 2016 us=967487 OPTIONS IMPORT: timers and/or timeouts modified
      Fri Feb 19 22:00:15 2016 us=967487 OPTIONS IMPORT: route options modified
      Fri Feb 19 22:00:15 2016 us=967487 OPTIONS IMPORT: route-related options modified
      Fri Feb 19 22:00:15 2016 us=970489 ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=22 HWADDR=fc:f8:ae:ad:04:ee
      Fri Feb 19 22:00:15 2016 us=982506 OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options
      Fri Feb 19 22:00:15 2016 us=982506 OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.1.1
      Fri Feb 19 22:00:15 2016 us=984007 open_tun, tt->ipv6=0
      Fri Feb 19 22:00:15 2016 us=985008 TAP-WIN32 device [NETGEAR-VPN] opened: \\.\Global\{B7A4985E-9669-4AFD-BCC2-BA2D9999BA5F}.tap
      Fri Feb 19 22:00:15 2016 us=985008 TAP-Windows Driver Version 9.21
      Fri Feb 19 22:00:15 2016 us=985008 TAP-Windows MTU=1500
      Fri Feb 19 22:00:15 2016 us=985508 Successful ARP Flush on interface [25] {B7A4985E-9669-4AFD-BCC2-BA2D9999BA5F}
      Fri Feb 19 22:00:16 2016 us=265760 Extracted DHCP router address: 192.168.1.1
      Fri Feb 19 22:00:20 2016 us=104442 TEST ROUTES: 1/1 succeeded len=0 ret=1 a=1 u/d=up
      Fri Feb 19 22:00:20 2016 us=104442 C:\WINDOWS\system32\route.exe ADD XXX MASK 255.255.255.255 192.168.1.1
      Fri Feb 19 22:00:20 2016 us=106929 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
      Fri Feb 19 22:00:20 2016 us=106929 Route addition via IPAPI succeeded [adaptive]
      Fri Feb 19 22:00:20 2016 us=106929 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 192.168.1.1
      Fri Feb 19 22:00:20 2016 us=110431 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
      Fri Feb 19 22:00:20 2016 us=110932 Route addition via IPAPI succeeded [adaptive]
      Fri Feb 19 22:00:20 2016 us=110932 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 192.168.1.1
      Fri Feb 19 22:00:20 2016 us=114434 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
      Fri Feb 19 22:00:20 2016 us=114434 Route addition via IPAPI succeeded [adaptive]
      Fri Feb 19 22:00:20 2016 us=114434 Initialization Sequence Completed
      Fri Feb 19 22:00:20 2016 us=114434 MANAGEMENT: >STATE:1455937220,CONNECTED,SUCCESS,,XXX
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi ThePie,
        1.      Is the main adapter still enabled and connected with valid IP address?
        2.      Make sure the main adapter doesn’t conflict with the OpenVPN router’s network. Ex if R8000 is 192.168.1.1, the outside LAN network should be on another subnet.
