caseyf5
Mar 12, 2016Aspirant
R8000 problem with security gateway.
Hello Help Center, I'm having problems with the (CUJO) security gateway. ARG and Metadata from this gateway are causing continuous MAC changes in my R8000 AC3200 Nighthawk AC3200 Tri-Band WiFi Route...
- Mar 13, 2016
caseyf5,
Thanks for clarifying things. I know what ARP is and how it works. I did some Googling and according to a few sources, the CUJO box uses aggressive ARP spoofing to intercept traffic from all devices. It literally uses a textbook Man-In-The-Middle (MITM) attack to operate! LOL. Supposedly, the intercepted traffic is inspected and anonymized information is sent back to their servers. What actual information is sent and what it's used for is unknown. But if you aren't scared by what you've just read, you should be!
Netgear's business-class switches use Dynamic ARP Inspection (DAI) to combat ARP spoofing. It's possible that the R8000 has DAI, which would explain why it doesn't like the Cujo. If I were you, I would toss Cujo into the trash!
caseyf5
Hello TheEther,
Thank you for responding so quickly. Sorry I misspelled ARP as ARG. My bad typing and even worse proofreading. Their gateway mode uses ARP to acquire metadata (don't know exactly what metadata) from my network and it looks like my R8000 router doesn't like this one bit. This is why I'm seeing constant MAC changes (ARP deals with MAC address management). Yes the device constantly changes the MAC addresses every few seconds if not at an even faster rate. The only way to stop this was remove the CUJO security device! I even tried this with an older Netscape router the R4500 with the exact same result!
TheEther
Mar 13, 2016Guru
caseyf5,
