R4500
1 TopicR8000 problem with security gateway.
Hello Help Center, I'm having problems with the (CUJO) security gateway. ARG and Metadata from this gateway are causing continuous MAC changes in my R8000 AC3200 Nighthawk AC3200 Tri-Band WiFi Router which makes the network unstable and almost unusable. I also have the Netgear R4500 which has the same problem. I have contacted them and they are not as familiar with this model as they would like and they are doing research into getting this problem fixed. I am hoping that someone here has the answer / answers so I can assist them in resolving the problem. Any and all help would be gratefully appreciated.Solved3.8KViews0likes3Comments
