R4500
2 TopicsR4500 and Genie authentication problems
Hi, I have an R4500 router (also called N900) and till about 5 months ago, I was able to log in the Genie app that obiously was supported (also stated in the router Data sheet). Now, I can't log in anymore (doesn't matter if I try from the computer or the smarthpone). A red messages says that "Netgear router is not found or supported. Also make sure that the device is not connected to the guest network of the router and not IPv6 is anable". What should I do? Please help Thanks3.2KViews0likes2CommentsR8000 problem with security gateway.
Hello Help Center, I'm having problems with the (CUJO) security gateway. ARG and Metadata from this gateway are causing continuous MAC changes in my R8000 AC3200 Nighthawk AC3200 Tri-Band WiFi Router which makes the network unstable and almost unusable. I also have the Netgear R4500 which has the same problem. I have contacted them and they are not as familiar with this model as they would like and they are doing research into getting this problem fixed. I am hoping that someone here has the answer / answers so I can assist them in resolving the problem. Any and all help would be gratefully appreciated.Solved3.8KViews0likes3Comments
