VenezuelaDan
Aug 24, 2017Star
R8000 QOS Performance Optimization Database Not Updating
Hello, Whenever I try to update the Performance Optimization Database in the QoS, it says that it hasn't been updated, despite it from the end of 2015 (version 1.80,1.0.26 from 12/28/2015). My ro...
- Dec 29, 2017
Hi All,
QoS database will be updated in upcoming firmware release.
VenezuelaDan
Jan 16, 2018Star
Thank you again for your help on this issue. Will QoS databse updates after the firmware update be tied to FW updates, or will they be independently updateable?
Also, is there an estimate to when the next firmware update will come out?
Thank you for your time.
VenezuelaDan
Jan 23, 2018Star
Would it be possible to get and update to my 1/16 questions? I'd like to know if QoS databases after the next firmware update will arrive independently of updates (as initially intended).
Also, any word on when the next firmware update is to be released?
Looking forward to having this QoS issue solved. Thanks for your help.
