KevanB's avatar
KevanB
R8000 USB 3.0 No Disk
Just purchased X6S AC4000. Download latest firmware and set everything up. Then, plugged in my WD Passport 4TB external drive to the 3.0 USB and the drive is not found. When I tried to set it up in Re...
  • KevanB's avatar
    KevanB
    Jun 27, 2019
    Called support. They had me insert a flash drive into the USB 3.0 and it was recognized. I then plugged in the WD 4TB HD back into the USB 3.0 and it worked. Go figure.
