TJ_Dartss's avatar
TJ_Dartss
Initiate
Nov 28, 2018
R8000-V1.0.4.28_10.1.54 update problems
Model: R8000, firmware V1.0.4.28_10.1.54 update, Win10 OS
I have a 2Tb SSD external HD connected to the USB3 port on the R8000 router using ReadyShare to allow access from my network. I had it setup to be my default documents, pictures, etc, etc paths from my Win10 laptop. This was working without issue before the update but after the V1.0.4.28_10.1.54 update, ReadyShare isn't working and the 2Tb drive and ReadyShare itself can't be found in the network.
The 2Tb drive is still setup and authorised in the router setup, all settings are the same before and after the update (as far as I can tell).
I have obviously rebooted the router multiple times, unplugged and replugged the USB drive multiple times as well as checking all relevant settings to do with the ReadyShare and USB setups but to no avail...
Does anyone have a fix or more troubleshooting steps for this problem?
  • KiwiSpud's avatar
    KiwiSpud
    Nov 28, 2018
    I downgraded my R8000 to R8000-V1.0.4.12_10.1.46 tonight and it is stable and running well again. Next upgrade will wait until the code is fixed.
  • michaelkenward's avatar
    michaelkenward
    Did you reset the router to factory settings after the firmware flash?
    New firmware sometimes introduces changes that are not compatible with the old configuration.
    So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
    This is a nuisance because you then have to reconfigure the device all over again.
    You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
    • KiwiSpud's avatar
      KiwiSpud
      Tutor
      • IrvSp's avatar
        IrvSp
        Master
        If the code IS broken, it will never be fixed unless someone reports it, or NG had discovered the problem itself.
        I upgraded to the f/w level many months ago and have had no USB drive problems? Also on W10 V1809 Home with SMB 1 enabled.
        Question, from a Windows 10 CMD prompt, what do you get when you issue a NET VIEW command? Does it work at all?
        Wondering if you have a faulty upgrade, especially if it was done via wireless? Might want to re-try and see it if works.
