Gutie-850
Nov 19, 2018Aspirant
R8000 X6 Nighthawk “Problem Detecting the Internet Connection” during setup loop
I recently replaced a Cox router with a Netgear router. I have installed and connected it with my modem and as I connect to the Ethernet and WiFi (does not give internet), the pop up for routerlogin.n...
- Nov 20, 2018
What modem sits in front of this router?
It is hard to read your solid slab of text, so I can't tell if you have started everything in the right order.
Be sure to restart your network in this sequence:- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
When changing something on your network, it can also help to reset the modem and the router.
michaelkenward
Nov 20, 2018Guru - Experienced User
- Gutie-850Nov 20, 2018AspirantThe modem is an AARIS SURFboard SB6141.
Basically the (very) condensed version of my post is that after setting up a new router, I cannot connect to the internet to complete setup, not even with a MAC Spoofing.
Following the steps you gave me loaded a different page, but it failed to load the page and redoing the steps after that didn’t even allow me to log into routerlogin.net- michaelkenwardNov 20, 2018Guru - Experienced User
Gutie-850 wrote:
The modem is an AARIS SURFboard SB6141.OK. Modem. Not modem/router which eliminates one possible cause of problems.
I assume that the modem on its own still connects to the internet.
Have you tried resetting the modem to factory defaults?
When you start a modem and router, they communicate with each other and save various settings. I have found with my DSL modem that I sometimes have to reset both devices before they will play ball.
Which ISP is this?
You could try searching this forum for a combination of the modem and the ISP. Someone may have climbed the same learning curve in the past.
There is a manual for the R8000 at the end of this link:
>>>>> R8000 | Product | Support | NETGEAR <<<<<
- Gutie-850Nov 20, 2018AspirantI reset the modem to factory defaults, no change.
My ISP is Cox.
