Gutie-850
Nov 19, 2018Aspirant
R8000 X6 Nighthawk “Problem Detecting the Internet Connection” during setup loop
I recently replaced a Cox router with a Netgear router. I have installed and connected it with my modem and as I connect to the Ethernet and WiFi (does not give internet), the pop up for routerlogin.n...
- Nov 20, 2018
What modem sits in front of this router?
It is hard to read your solid slab of text, so I can't tell if you have started everything in the right order.
Be sure to restart your network in this sequence:- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
When changing something on your network, it can also help to reset the modem and the router.
IrvSp
Nov 20, 2018Master
Something doesn't ring true to me? Your message appears to be either incomplete or you have described something you attribute to the Router that might be due to TROUBLESHOOTING on a Windows PC using the NETWORK TROUBLESHOOTER...
Gutie-850 wrote:
I recently replaced a Cox router with a Netgear router. I have installed and connected it with my modem and as I connect to the Ethernet and WiFi (does not give internet), the pop up for routerlogin.net appears. It tells me that it is detecting if there is an existing router in my network.
OK, I think that is what happens when you use a Genie Mobile app to set up the router. Is this correct?
Gutie-850 wrote:
After that, it checks the internet connection. Here’s where the problem begins. I am given the option to use the NETGEAR Genie to help, however neither assist me.
What EXACTLY did you see here at this step? What do you mean by 'neither'?
Gutie-850 wrote:
I attempted to configure by myself, but some of the options were limited as I was not connected to the internet. I couldn’t find a way to fix this, so i factory reset the router to see if I can change this.
How did you attempt to configure it? What steps? What was limited? Where was it trying to go on the internet. I'll assume you were connected to the router using a Wireless connection, not a Wired one?
Gutie-850 wrote:
I ask the Genie for help and it brings me to a page telling me to power cycle my modem and correct a problem with the yellow Ethernet cable because there is a problem detecting the internet connection. Clicking either one will load a page that attempts to connect to the internet, yet it leads back to the same page. Clicking “None of the above” asks if my ISP gave me a static IP. I did not, so I click No.
I never saw it do this? What 'yellow Internet Cable' are you talking about and where is it? You mean the cable between the modem and router? What is the LED colors like, off, on, white, orange?
What are you answering with 'None of the above'?
For the page, paste in the URL that you are looking ar please.
Gutie-850 wrote:
Then, it requests my computers MAC address. Trying to spoof this leads back to the “Problem Detecting the Internet Connection.” (this also appears if you click “I don’t know” on the previous page.) No matter what I do, I am stuck in an infinite loop of the NETGEAR Genie telling me it cannot connect to the internet. I’ve tried anything, please help and thank you for reading. I’ve provided an image to show what page I’m always led to.
I've never seen a request for a MAC Address either? It seems it all points back to the modem and router are not connected OR the modem doesn't recognize your router?
I can NOT see any attacked file or screen capture.
It might be the MODEM needs to be reset, either by you or the ISP as it is looking for the OLD router and will only connect to it? That was possibly the MAC Address it was looking for, but I wouldn't think Genie would ask for that, but maybe the modem?
Have you ever turned off BOTH the modem and router, then turned on the modem, and when it was fully up, the router?
