luisescorza
Apr 14, 2021Tutor
R8000 Xfinity Slow speed
Any one having or had slow speeds with their R8000 and xfinity comcast? I should be getting close to 400 meg but both wired/wirless are capping out at around 100 meg or less. Plugged stragign into...
Dscottz247
Apr 14, 2021Aspirant
I am having the same issue with comcast. I should have 1000Mbps and only getting 150 on wifi. Router shows the same speed when tested but on wifi it is much slower. Not sure what the problem is.
Dscottz247
I was reading on here that it may be an issue with the firmware update and that a factory reset may help. I will try it out and update if it works.
- luisescorzaApr 14, 2021Tutor
I actually was on the latest firmware update. But read on a thread to revert to the 1.0.4.28 firware and do a factory reset. Howeve, still having the same issue. :(
- Dscottz247Apr 14, 2021Aspirant
Yea, i just did a factory reset went through the entire process and still very slow wifi speeds. Internet and router speeds are 900 and wifi is 60 really bad. Not sure what to do.
- luisescorzaApr 15, 2021Tutor
Yeah me either. Its really frustrating. This router is like 2 years old and was over $300. Some one from Netgear support need to attend all these firmware issues. Not sure whats going on. CUSTOMERSERVICE
