luisescorza
Apr 14, 2021Tutor
R8000 Xfinity Slow speed
Any one having or had slow speeds with their R8000 and xfinity comcast? I should be getting close to 400 meg but both wired/wirless are capping out at around 100 meg or less. Plugged stragign into...
Dscottz247
Apr 14, 2021Aspirant
I was reading on here that it may be an issue with the firmware update and that a factory reset may help. I will try it out and update if it works.
luisescorza
Apr 14, 2021Tutor
I actually was on the latest firmware update. But read on a thread to revert to the 1.0.4.28 firware and do a factory reset. Howeve, still having the same issue. :(
- Dscottz247Apr 14, 2021Aspirant
Yea, i just did a factory reset went through the entire process and still very slow wifi speeds. Internet and router speeds are 900 and wifi is 60 really bad. Not sure what to do.
- luisescorzaApr 15, 2021Tutor
Yeah me either. Its really frustrating. This router is like 2 years old and was over $300. Some one from Netgear support need to attend all these firmware issues. Not sure whats going on. CUSTOMERSERVICE
- night1Apr 16, 2021Aspirant
OK we will try this one more time.
The R8000 is junk after 2 years of owning it,
I only get 350DL on lan should be like 1,000DL
I have Xfinty and get +-20% of my speeds 1,000DL 50UP on (netgear modem ) when tested.
When I test off the R8000 I am lucky to get 350DL on lan cat 5e WIFI is about 150DL
I do use cat7 from modem to router and to a Desktop PC.
I been have update the frimware reset powed off back on still the same.
Now I am thinking putting in the trash what a big waste of my money and time.
Netgear was good at one time.
Time to replace it some thing not sure what yet.
