ionhirsch's avatar
Sep 19, 2022
R8000P — Nighthawk X6S AC4000 Tri Band WiFi Router
Hi all
This router doesn't want to connect through PPPoE
This is the third Netgear router with the same problem
As a standard cable router works great, but doesn't want to conect through PPPoE
Is enybody there that can hel ???
  • plemans's avatar
    What device are you connecting it to?
    Did you check with your isp? many people on here use PPPoE without issues
    • ionhirsch's avatar
      ionhirsch
      Guide
      I am connected straight to the media converter.
      ISP router connects easily, but not the Netgear
      It happen the same thing with the other Netgear router back home in Romania
      no PPPoE
      I will re check the login details again to be sure
      • plemans's avatar
        What media converter/gateway are you plugging it into?
        Have you checked with your ISP? Some require you to use their device.
        Usually there's a workaround if thats the case but it usually involves a bit of research about your isp/gateway to figure out exactly what steps are needed
