redmarkred's avatar
redmarkred
Initiate
Aug 04, 2021
R8000P — Nighthawk X6S Firmware Wont Update
The firware wont update on this router. Have tried using the updte on the routerlogin.net page and also by manually uploading the firmware file but no matter what I do the version number remains the same (V1.4.1.50_1.3.10)
1 Reply
  • Greetings.  This is a known problem it really has nothing to do with you.  Unfortunately you will have to play the "Support Game".  They hold all the cards, just submit, and provide them with any info they want.  It's a shame that so many people are ready to write off Netgear because of a firmware update.  I will match my Nighthawk R8000P performance wise with ANY router out there presently.  I had the same firmware issue that everyone else had, bite the bullet and play the game.  Resistance is futile. LOL.  I'm running 85 online devices flawlessly.  I am totally satisfied with Netgear.  Their support leaves a lot to be desired but then again too, you just can't give out an unlimited supply of $300 routers.  Good luck to you, and remember, just play the game.
