Caffeine-Badger
Sep 19, 2025Follower
R8000P [DOS Attack: Fraggle Attack]
Netgear Nighthawk X65 AC4000 Model R8000P Firmware V1.4.4.94_1.3.56 When I view my Administrator Log I see reoccurring logs every minute [DOS Attack: Fraggle Attack] from source [my public ip] ...
Sep 19, 2025Guru - Experienced User
Caffeine-Badger wrote:I’m not an expert, but from what I can gather it shouldn’t be possible to get a real DOS Attack that comes from my own IP
The source IP address is often spoofed by the attacker (replaced with a different one to hide the source). And it is fairly common to replace it with the destination IP address (which is your router's WAN address).
As FURRYe38 says, the attack was detected. But your ISP should know about IP-spoofing, and IMO should have followed up. It is a denial of service attack, so it is intended to flood their network with these attack packets.
If you use torrent software, you might turn that off for a while, and see if the reports stop.
