mchensky
Oct 31, 2017Aspirant
R8000P dropping wifi connection
Hello, I own a Nighthawk X6S (R8000P) and I've been having an ongoing issue where after I've been surfing via wifi for some time the wifi connection will remain active however there is no data up/dow...
- Jun 11, 2018
So I updated to Firmware V1.4.0.10 5 days ago. So far no internet drops :smileyhappy:
Haven't tried installing my USB hardrive to see if network storage works again. Just updating everyone.
WheelsUp
Nov 26, 2017Aspirant
I am also having the same issue with my router. It is very frustrating to say the least since I rely on WiFi calling in my home due to a poor cellular connection. I have to powercycle the router by upluging/pluging in order to fix the issue. My ISP is AT&T Uverse. All available firmware updates have been insttalled. Any help will be aprreciated.
Thanks,
Rob
asc317
Dec 01, 2017Tutor
I'm having the same issues. On my second one, same issue. Any Netgear reps with advice before I scrap this and switch brands?
- rayny2eDec 04, 2017Star
I have the exact same product with the exact same issue. I have posted and asked for any help on this but got no reply at all,not even from netgear. I’ve only had this pos for 60 days and have yet to be able to have it work properly. It locks up every 24 hours,even though it thinks it’s connected! The only way to get it going again is reboot. I’ve put my old R6300v2 back online and I have no issues! I wasted $320.00 on this piece of junk!!
- VolstateDec 04, 2017Apprentice
Folks I suggest trying to disable the 5 GHZ band and only use 2.4 GHZ. This issue is on the 7000 model as well and when I made this change I haven't had any resets since. Netgear needs to figure out the issue and get this fixed ASAP!
- asc317Dec 04, 2017TutorYou're kidding right? This is an ac4000 triband router. We spent what we spent on it for a reason. If I just want single 2.4 I can dig out my old wireless g dlink...
I mean I appreciate the suggestion and all, but if this expensive brick doesn't work unless you disable some of the main advertised features, that's not actually a solution, is it?
