mchensky
Oct 31, 2017Aspirant
R8000P dropping wifi connection
Hello, I own a Nighthawk X6S (R8000P) and I've been having an ongoing issue where after I've been surfing via wifi for some time the wifi connection will remain active however there is no data up/dow...
- Jun 11, 2018
So I updated to Firmware V1.4.0.10 5 days ago. So far no internet drops :smileyhappy:
Haven't tried installing my USB hardrive to see if network storage works again. Just updating everyone.
MrLiDo
Dec 20, 2017Aspirant
Netgear users,
A montth ago (November 2017) I have received an email from Netgear, urging me to update the firmware on my router. I followed Netgear's instructions and succesfully upgraded the firmware to the latest version. Promptly, my router started freezing, dropping the internet connection on all my devices. I called support, and was told that since I purchased the unit in December 2015 I am out of warranty and, basically luck.
I argued that my router would have worked just fine if I would have ignored their urgen plea to upgrade the firmware and so they have decided to give me some free support. After reseting the unit to factory settings, change a few setting values, and finally revert to the previous firmware version the support specialist decided that "unfortunately I'm gonna have to purchase a new unit"
Netgear, this is on you. You prompted me to make an update that rendedred my router useless. Based on many other users facing the same problem, one can only wonder. How convenient for Netgear to put out a malicious "update" and simply turn their back on the customers not covered by the 1 Year warranty, giving them the option of buying a new unit. I will buy a new unit, but you better believe it it will not be a Netgear brand. As far as I am concerned, you just lost me, my business and my circle of influence business as customers.
Liviu A Dordea
