mchensky
Oct 31, 2017Aspirant
R8000P dropping wifi connection
Hello, I own a Nighthawk X6S (R8000P) and I've been having an ongoing issue where after I've been surfing via wifi for some time the wifi connection will remain active however there is no data up/dow...
- Jun 11, 2018
So I updated to Firmware V1.4.0.10 5 days ago. So far no internet drops :smileyhappy:
Haven't tried installing my USB hardrive to see if network storage works again. Just updating everyone.
rayny2e
Dec 23, 2017Star
Please reply back on here to let us know how you made out after the Firmware rollback. When I did mine, i Did NOT Use smart connect as my personal feelings think it's a waste and does NOT work as intended. I'm having better luck use the 3 separate SSID's. I just hate using old, outdated firmware on a Router that cost me over $300.00 :(
MrLiDo
Dec 26, 2017Aspirant
The rollback to the previous version caused my router to reboot itself. Prior to that was freezing, now rebbots itself every other hour or so. Rolling back to an even earlier version didn't do anything. It's worth doing the following to have some sort of success:
1 - Download to your PC the soft version you want to use.
2 - Reset the router to factory settings
3 - Upload the soft version you want to use immediately.
4 - Pray and hope.
Good luck.
- TerryPhDec 27, 2017Virtuoso
Try version 1.0.3.54. it has been very stable for most of us
