mchensky
Oct 31, 2017Aspirant
R8000P dropping wifi connection
Hello, I own a Nighthawk X6S (R8000P) and I've been having an ongoing issue where after I've been surfing via wifi for some time the wifi connection will remain active however there is no data up/dow...
- Jun 11, 2018
So I updated to Firmware V1.4.0.10 5 days ago. So far no internet drops :smileyhappy:
Haven't tried installing my USB hardrive to see if network storage works again. Just updating everyone.
sheikh73
Jan 05, 2018Aspirant
No I was not able to revive it so far. I get power led flashing only if no network is connected, if I connect my computer with wire then one white led get lit. I did 30-30-30 a few times so far but without any recovery.
TerryPh
Jan 05, 2018Virtuoso
Symptoms:
Router not booting up properlyFailed firmware updateBlinking power LEDPower LED is blinking/solid amber
I guess you have to use tftp approach to get it work agan.
To reinstall the firmware:
Download the latest firmware for the router, from http://support.netgear.com. It may download as a .zip file, containing the firmware and some documentation. Unzip it.Download the TFTP client software “tftp2.exe”, which can be downloaded from http://www.shadowsoftware.net/shadowgameworld/downloads/.
For Mac users, please download the software on this link: http://download.cnet.com/MacTFTP-Client/3000-18508_4-5707.htmlTo do these downloads, you may be able to access the internet by connecting the computer directly to the cable modem, or you may have to use another router or another internet connection.Connect the computer to the router and assign a static IP of the router's default range (192.168.1.x or 192.168.0.x) on the LAN connection.If you ping the router's IP you should be getting replies now.Now run the tftp2.exe file that was downloaded earlier.
In the Server field, enter the default IP of the router.In the Password field, enter the default password of the router.In the File field, browse and locate the firmware file that was downloaded earlier.Turn the router off for 10 seconds and turn it back on.While the router is still in the boot process (ie. Power light is still 'amber') click Upgrade and wait for the process to be completed.Once the process is complete, the power light will turn steady green.
- sheikh73Jan 06, 2018AspirantI followed the guide a few times but all 3 tries fail.
- TerryPhJan 06, 2018Virtuoso
Hi. sheikh73.
Sorrry that you could not get this router back to work. In the interest of getting some light into it, I wonder:
1. Did you get to ping sucessfully 192.168.1.1 address before running tftp2 software (by command run, cmd, ipconfig, and ping)?
2. What was the DNS configuration before you ran tftp2 software?
3. Did the amber power LED still stay amber solidly even after trying tftp2?
Worst case scenerio, if you bought this router within a year, you can call customer support and elevate the case to hardware failure, and very possible that Netgear will swap you a new one.
- DjRiDeJan 06, 2018ApprenticeI'm in my return period for an exchange. But makes no sense for me if it's firmware issue that Netgear is not addressing. Can't go three days without having to reboot the router to keep my internet connection. I love the router when it works. Looking for an alternative router with same capabilities. 😩😩😩
Yeah, I have been dealing with this problem from early December, and have been contacting Netgear. It was a headache but I manage to reverse my router to the older version and it has been so stable until today without any problem. Any firmware version earlier than the one dated December 2017 would be ok. I am still working/testing the beta version of the R8000 to see if it is better in terms of internet stability, DNS addressing conficts, etc. Hopefully Netgear engineers will figure out why the December FWs failed in many of their router models.
- sheikh73Jan 06, 2018AspirantHi Terry
I don't know how but after pressing the reset button numerous times and many different other methods router restarted by itself. Tftp2 didn't flash the firmware, I was getting ping on 192.168.1.1 but after router rebooted, I got my old configuration back with 10.0.0.1 IP address and old password as well. This Netgear router is funny. I had no hopes and it came back to life by itself.
I have reflashed it and also factory defaulted as well. So far it's working as normal.
Thanks for your help.
Rashid - TerryPhJan 06, 2018VirtuosoHi Rashid,
It's good now that you have a working router. Really to save yourself a headache, if you can get to router interface and see any firmware in your router different than v.1.0.3.54, please downgrade to this version. At present time, this version seems most certainly stable, as I have been trying everything else, including the beta versions that NETGEAR engineer sent to me. The latest beta version just tested yesterday and today to no good working one. And I think I had pretty much idea what was causing the whole fiasco with newest firmware, in general.
Just stay with older version 1.0.3.54 until they figure it out. Don't touch the newest versions 1.0.4.4.x.x.x... you will get into problems soon with it.
Best - drobertJan 07, 2018Aspirant
How do I get back to the order firmware version (1.0.3.54) so I can re-install that? I upgraded to firmware version 1.0.4.4 and starting having problems everyone else has been posting.
- windsagaJan 07, 2018NETGEAR Employee Retired
Hi Terry,
You recommand FW version is R8000 not R8000P.
- TerryPhJan 07, 2018VirtuosoYeas. Just found out. For R8000P, the older Fw 1.3.0.4 or 1.2.1.6 .
- DjRiDeJan 08, 2018Apprentice
Just to confirm:
Firmware: R8000P-V1.3.0.4_1.1.96
Is a good firmware to revert back to and should have no internet drops again? I been reading two different post and one says the above and another says to go to R8000P-V1.2.1.6_1.1.86
I just updated to R8000P-V1.3.0.4_1.1.96 but i wanted to confirm so I conclude my testing to decide if I will keep the router or return. Dont have much time left in my return period.
I appreciate your help!
- windsagaJan 08, 2018NETGEAR Employee Retired
Hi DjRiDe, May I know which FW let the internet drop . v1.3.0.8 ? or v1.3.0.4 ?
You may try to rollback to v1.2.1.6 after data capture.
Thanks
- DjRiDeJan 08, 2018ApprenticeHello,
I know v1.3.0.8 dropped after 3 days. I just bought the router less than a month ago and I didn't look to see what firmware the router was on before I upgraded. So I wasn't really sure which to revert back to. Currently just reverted back to: v1.3.0.4
Thx - DjRiDeJan 10, 2018ApprenticeUpdate::::
1.3.0.4 - still needs rebooting every three days.... I just loaded the previous firmware now. Looks like I will be strongly considering returning for a linksys or asus compatible....
Previous Reply::::
I just updated to R8000P-V1.3.0.4_1.1.96 but i wanted to confirm so I conclude my testing to decide if I will keep the router or return. Dont have much time left in my return period. - TerryPhJan 10, 2018Virtuoso
Hi DjRiDe.
I do understand your decision to return and consider getting asus or linksys router, after many headaches that you went through. Btw, I am also a favorite user of asus routers in the past, but I also like Netgear due to their solid hardware and stability in the past. I think Netgear recently tries to update most of their newer router models and this cause lots of problems. I myself had many days of headaches with my R8000 router which has been stable prior to updating to new firmware in early December last year.
Since then, I reversed back to the old stable firmware version and the router works flawlessly with some minor inconveniences.
Last straw for you, if you do not mind, is to reverse to earlier FW version, may be v1.2.1.6 or earlier v1.1.4.6 for your R8000P or any version that DOES NOT involve Disney Circle (parental control) feature, because I suspect that this feature more likely causes the problems with USB connection, internet connection instablility and a host of other problems involving DNS server etc.
Let me know if you really want to downgrade again and give it few days more before you return the product. And that is totally understandable..
Hi Terry,
On my R8000P I updated this morning to:
Firmware Version
V1.2.1.6_1.1.86I'm a little skeptical in keeping it though. This is my first netgear router - always had linksys in the past. My house recently having more and more smart devices throughout that why I went with this router to have a stable connection for all my tv's, thermostats, doorbell, camera's and all personal devices. I wanna say there's probably at least 30 things connected to wifi in my 3000 square foot (2 story) house. Like I said when this router is working its amazing! Just in the middle of the night it will hang up the internet upload or download (no internet) but network still there and connnected. Reason for being skeptical i have probably a little over a week before I lose my return window. I'm happy if it continues to work fine on this lower firmware but afraid that after my return window I will have issues with newer firmware releases and I'm stuck with this. So i'm actually at a loss as to what to do. Seen some good reviews on the linksys ea9500 and the asus 5300. So I gotta really decide quickly whats the best thing to do as well.
Thanks for your assistance!
Yeah. If this is the case, I would do the same, returning the router, too , because one week is too short for any hesitation.
Asus has been excellent in their routers, particularly high-end ones. Their AC routers seems to be very stable ( My other 2-story-house
with ASUS RT-AC3200 works perfectly with covergage more than 3000 sqft).
Well, good luck for you then.
- windsagaJan 10, 2018NETGEAR Employee Retired
Hi DiRjDe,
Did you connect USB device ? I would like to know if uSB device let DUT crash and let sustem reboot.
System reboot let internet disconnect.....
- DjRiDeJan 10, 2018ApprenticeThanks Terry!
Hi Windsaga,
I did not connect any USB devices currently as my main concern was to have stable internet. After that I was gonna worry about adding a hard drive for network storage. - TerryPhJan 10, 2018VirtuosoHi DiRjDe.
Since you just downgrade to older version, and I don't have R8000P to confirm, can you
1. Confirm if the version you are running on your router has the Disney Circle feature on It?
2. If it does not have Circle parental control or anything involving Circle , can you let us know tomorrow if your router running stable. You have one week left to return if it gets "crazy"again😊😊.
3.FYI. Just received email from NETGEAR Production Manager confirming what I thought was the root cause of problems.... and they are working hard to debug it.
Thanks
Terry - DjRiDeJan 10, 2018Apprentice
Hi Terry,
I had to create an account access the parental side of the router settings. I just did and when i went to it I didnt see anything about disney controls - Here's a screen shot of it.
- TerryPhJan 10, 2018VirtuosoHi DjRiDe,
I assume that you created parental control account by DDNS account, if you don't have Circle, and this confirms that you are running older firmware version.
Please, please, please let us know tomorrow if any problems at all with the router functions.. This is also for my curiosity...
Thx
Hi Terry,
That is correct - thats what I had to create the account for. As of right now I'm still up and running with no issues on
Firmware Version
V1.2.1.6_1.1.86I put this on this morning around 9am - normally its about 48hrs to 72 hrs where I get the hang ups - will report back tomorrow (24 hrs) as well - just think its too soon to conifrm as well
- TerryPhJan 10, 2018VirtuosoGood to hear that. If by tomorrow you don't have problem, then chances are you will be ok. Let's just hope it will be stable until Sunday evening, that is way past 72 hours and still have few days left for return...
Best,
Terry - DjRiDeJan 11, 2018ApprenticeUpdate:
24 hours on:
Firmware Version
V1.2.1.6_1.1.86
So far no issues - internet hasn't went down - windsagaJan 11, 2018NETGEAR Employee Retired
Hi DjRide,
May I know your internet type? PPPoE or DHCP?
ISP is Arris ?
