mchensky
Oct 31, 2017Aspirant
R8000P dropping wifi connection
Hello, I own a Nighthawk X6S (R8000P) and I've been having an ongoing issue where after I've been surfing via wifi for some time the wifi connection will remain active however there is no data up/dow...
- Jun 11, 2018
So I updated to Firmware V1.4.0.10 5 days ago. So far no internet drops :smileyhappy:
Haven't tried installing my USB hardrive to see if network storage works again. Just updating everyone.
windsaga
Jan 25, 2018NETGEAR Employee Retired
Hi Muh,
May I know your ISP and Internet setting ? (PPPoE ? DHCP?) and Modem model name ?
Did you attached USB device to router which contains media file ?
muh
Jan 26, 2018Guide
Windsaga:
The ISP is Mediacom the router has been configured as DHCP. The Ping test result for the largest non-fragmented packge size is 1472 so I am using the default MTU 1500.
The modem model name is R8000P Nighthawk X6S-AC4000 Tri-Band WiFi Router.
I do have an Seagate external hard drive connect to the Router through USB3 port. which contains media files
The router has the newerst Firmware 1.3.0.8
