mchensky
Oct 31, 2017Aspirant
R8000P dropping wifi connection
Hello, I own a Nighthawk X6S (R8000P) and I've been having an ongoing issue where after I've been surfing via wifi for some time the wifi connection will remain active however there is no data up/dow...
- Jun 11, 2018
So I updated to Firmware V1.4.0.10 5 days ago. So far no internet drops :smileyhappy:
Haven't tried installing my USB hardrive to see if network storage works again. Just updating everyone.
Tren
Feb 12, 2018Aspirant
I have been having the same issue with the R8000P dropping every 24 hours with tech support no help. They actually act as if they have no knowledge of this issue. Is there a fix yet?
- windsagaFeb 12, 2018NETGEAR Employee RetiredDid you use Comcast ISP ? Maybe ISP's problem.
- TrenFeb 12, 2018AspirantNo I do not use comcast.
- MrJaceFeb 22, 2018Tutor
I'm assuming there are no new updates on the progress of the actual fix.
I'm on the latest firmeware version. I had disabled QoS at one point, but after seeing no improvement, I turned it back on. And oddly enough - it went from an every day reset to an every 4 or 5 days reset. Not quite sure why there's a difference, but I'll take it until we get a resolution.
