mchensky
Oct 31, 2017Aspirant
R8000P dropping wifi connection
Hello, I own a Nighthawk X6S (R8000P) and I've been having an ongoing issue where after I've been surfing via wifi for some time the wifi connection will remain active however there is no data up/dow...
- Jun 11, 2018
So I updated to Firmware V1.4.0.10 5 days ago. So far no internet drops :smileyhappy:
Haven't tried installing my USB hardrive to see if network storage works again. Just updating everyone.
JamesGL
Dec 11, 2017NETGEAR Employee Retired
Hi All,
Just want to verify the following.
1. Are the devices still connected to the wireless network but no internet access or the network disappears?
2. If it is still connected to the network but no internet access, is wired connection working?
3. Does disconnection happens on both bands?
4. Have you tried changing channels for both networks?
5. I assumed most of you has done factory reset but just want to verify it the said step has been done.
robpod
Jul 08, 2018Aspirant
The posted solution does not work. I just bought the router a few weeks ago and am hving this issue. It is updted to the current firmware.
to answer the questions:
1. Yes, devices re connected to wifi but have no internet access. The Nighthawk app on my iphone can connect to the router and shows full internet connection via speed test, but running speedtest from browser fails
2. wired works perfectly
3. from what I ccan tell this happena on all bands
4.no, do no know how to do this
5.yes, several times.
Please help, this needs to work without having to manually reseat daily
- StarwoodZeroJul 09, 2018Aspirant
Just for the sake of deduction, did you try a factory reset after the most recent firmware was applied?
