mchensky
Oct 31, 2017Aspirant
R8000P dropping wifi connection
Hello, I own a Nighthawk X6S (R8000P) and I've been having an ongoing issue where after I've been surfing via wifi for some time the wifi connection will remain active however there is no data up/dow...
- Jun 11, 2018
So I updated to Firmware V1.4.0.10 5 days ago. So far no internet drops :smileyhappy:
Haven't tried installing my USB hardrive to see if network storage works again. Just updating everyone.
StarwoodZero
Jul 07, 2018Aspirant
Hello,
New to this board. I recently purchased this a few days ago. Upon setup for the first time, I updated the firmware to the most recent version. I began to notice the symptoms described on earlier posts, occuring about 1 day apart.
Recently I performed a factory reset, and re-applied all of the settings I had before, which was a pain, but now done.
I am now in day 2 and so far the connections have held. My setup is pretty much out-of-the-box setup, except that I use Netgear's version of MAC filtering called "Access Control". If anything changes I'll report in, but those still experiencing the issue after the firmware was applied, should try the same factory reset to see if there is an improvement.
StarwoodZero
Jul 13, 2018Aspirant
Just an update to my Jul 7, 2018 post. The router has been up for 6 straight days without an issue and I have not had to reboot once. So if anyone hasn't tried this, it's probably best to give it a try to see if it stabilizes the router properly.
