nyinyi82
Mar 11, 2026Initiate
R8000P firmware - 1.4.4.94_1.3.56 (beta version)
I was just given a Netgear X6S R8000P. My current firmware is 1.4.4.94_1.3.56. I read somewhere in this community that there is a beta version of 1.4.4.94_1.3.56 firmware. Does anyone have the link for the beta version? I can't find it to download anywhere. I would appreciate if anyone can share it with me. thanks, Nyi
Sent you a PM.
The r8000p is EOL.
https://www.netgear.com/about/eos/
You won't see development on it. You might check some of the 3d party firmware sites to see if there's any updates there for 3d party firmwares.
Sent you a PM.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
