Mister62's avatar
Mister62
R8000P My router won’t e-mail the logs to my gmail account
My router won't email the logs to my gmail account. Message: email failed 5.7.8 Username and Password are not accepted. I have triple checked the username and password.
  • Mister62 wrote:
    I am using:
    smtp.gmail.com
    If it doesn't send a test message, then maybe gmail won't work.
    I couldn't tell from your first message meant by "Username and Password are not accepted". You didn't say which username and password. If it was the email ones, that would explain it.
    I vaguely recall that gmail doesn't work with logs.
    Outlook.com works for me, and you can get a free account.
  • michaelkenward's avatar
    michaelkenward
    Which mail server are you using for the SMTP settings on your Your Outgoing Mail Server?
    Not all servers work with the log settings.
    I use outlook.com.
        michaelkenward
        Mister62 wrote:
        I am using:
        smtp.gmail.com
