AlbertShym
Jan 17, 2018Guide
R8300 - Support for MD5 Certificates with Built-In VPN
OpenVPN has announced that they will be ending support for MD5 certificates in April of 2018. If that means that I will not be able to use the VPN feature of my router, I am wondering if there will be a firmware update that will replace this outdated security method.
Hi AlbertShym,
I am sorry for the confusion. What I meant was the NETGEAR will be supporting the new certificate that OpenVPN uses before it stops supporting the MD5 certificate.
- JamesGLNETGEAR Employee Retired
Hi AlbertShym,
NETGEAR will support MD5 certificates for OpenVPN. It will be release before April of 2018.
- But since NETGEAR's VPN solution uses MD5 certificates, will NETGEAR update the VPN solution to use more secure certificates?
Hi AlbertShym,
- I see now. Thanks!
