Vlad777777
Jun 03, 2021Follower
R8300 extend with MK83 mesh
I have Nighthawk R8300 router and it does not reach all areas. I just ordered MK83 three unit mesh but would like to use it with R8300 by connecting the mesh units via harwired LAN. What is the best way to do it?
I would like to presrve the names and IP addresses of the currently connected clients. Can this be easìly done?
I wanted to disable wireless on R8300 but keep wired gigabit lan network and use mesh MK83 for wireless network while keeping current wireless network names... Hope someone can help with advice.
I've done it several times.
Just go:
modem---->r8300 (router mode)----->MR80 (access point mode)-----> MS80 satellites
Make sure the mr80 is in access point mode to prevent a double nat. then just set the mr80 with the same ssid you had on the r8300.
You wouldn't need to disable wifi on the R8300 but use a different ssid and make sure its using different wireless channels from the mk system to prevent interference. then you'd have a backup wireless or even a wireless you can offload devices to like IoT devices or fixed position devices that are close.
I have a similar setup with an R7800 and a string of Orbi router (AP mode) and satellites.
Works just fine. I even use Powerline to link the R7800 to the Orbi.
