Gimli8892
Aug 19, 2022Aspirant
R8500 — NIGHTHAWK X8 AC5300 SMART WIFI ROUTER UPDATE WON'T LOAD
Trying to update from v1.0.2.122 - Android App shows v.1.02.160 is available but update doesn't work - failure message with no code - just offer to try again later.
Try the manual FW update as suggested here:
Seen problems with updating FW using the NH app...not really recommended.
- Gimli8892Aspirant
Not helpful. The login link takes me into the netgear website to my account. Once there, I seem to be going in circles on the website.
You would think they would have a link to simply download the update.
Are you selecting the DOWNLOAD LINK seen in that thread? That will take you here:
Download Link: https://www.netgear.com/support/product/R8500.aspx#download
