wlh2
Jan 20, 2017Tutor
R8500 5GHz band 1 does not work.
I have had the r8500 since early December. Today, as I noticed my laptop in a certain spot had jumped to the 2.4 band as opposed to the 5GHz, I decided to see if maybe one of the 5GHz channels was b...
- Jan 28, 2017
Return it or file a warranty claim if the 5GHz channel dies.
just posting to "mark as solution" for others...
wlh2
Jan 20, 2017Tutor
Additional info: The white light on both 5GHz bands on the router are active. There is still no visible network "5Glow", as I've named it, on any device (phones, tablets, laptops, and a desktop). There is no active lower 5g band on any wifi scanning app. Nor can I connect to "5Glow" by typing in the SSID directly on any device.
Jan 20, 2017Guru - Experienced User
You might first see if you can exchange the router. If not, I'd contact support and ask for an RMA.
- wlh2Jan 20, 2017Tutor
Hi - yes, thanks for the reply. I checked after my first post and I have until Jan 31 to return it to Amazon. Thought it might be worth a shot to see if I'm just missing something simple that others have had / solved. But having searched the forums a bit, this seems like might be a bad 5g antenna? Thanks.
- StephenBJan 20, 2017Guru - Experienced User
The band that's failing uses active antenna technology, so you won't be replace that antenna yourself anyway. I'd just exchange it.
