chascent
Feb 11, 2016Luminary
R8500 Constant WAN Internet disconnects/connects!
My wireless is rock solid, never disconnects. The WAN is another problem, see below from log: [Internet disconnected] Thursday, Feb 11,2016 02:35:35 [Internet connected] IP address: 192.168....
- Mar 24, 2016
Same problem here (I started the thread) WAN disconnects.
Cable company came out and tested and replaced the Modem.
2 Hours later I had a WAN disconnect. RMA # 2 will be here today.
I never had this problem with the R7000!
CC
ElaineM
Feb 11, 2016NETGEAR Employee Retired
Can you guys try to lower down your MTUs?
See this link.
gdclark1041
Feb 12, 2016Tutor
I worked directly with my ISP to calculate the MTU rate and 1500 is where we landed. I tried lower rates, but no changes to the disconnect behaviors.
My calculation -
max packet size (ping test) + IP and ICMP headers = MTU size
1472+28 = 1500
- chascentFeb 14, 2016Luminary
All I am beta testing a new firmware and the WAN disconnect issue seems to be resolved!
Also the radio scheduling issue. Running abot 2 days now no WAN disconnect. Before I would
have at least 1 every 4-5 hours.
CC
