RealDogfart
Nov 23, 2016Guide
R8500 Log Files Not Clearing
I've setup daily log file emails. After receiving the message I usually check the log and then clear it. The next day I get the same log file. I've tried clearing, refresshing and applying but I s...
- Jan 23, 2017See what happens when you wait long enough? Firmware V1.0.2.86_1.0.75 was issued. The release notes are not specific: "Bug Fixes: Improved security protection on device web server." So whether the update actually fixed the problem or the firmware being flushed and refreshed the issue appears to have been resolved. After the update a cleared the log and viola, the log file actually cleared. If I notice any more issues I'll come back and make comments but I consider this issue resolved. Thanks.
ElaineM
Nov 28, 2016NETGEAR Employee Retired
Welcome to the community, RealDogfart
What kind of log files?
Are you saying that the log files are the same time and date or same logs with different time and date?
Can you post a screenshot?
RealDogfart
Nov 28, 2016Guide
I don't know what kind of log files. I'm not sure where the router stores it's logs or whether I have access to them. What I'm referring to is under the Advanced Tab/Administration/Logs. Secondly, under Advanced/Security/Email I've checked 'Turn E-mail Notification On' And, at the bottom of the page I've setup 'Send logs according to this schedule' DAILY. I'd love to paste a screen shot but that's not an option in this messaging system.
- ElaineMNov 28, 2016NETGEAR Employee Retired
That's right, those are the log files. That's the only place to see the logs.
Are you getting the same logs everyday with the same date and time?
You may post your screenshot by clicking the image icon.
- RealDogfartNov 28, 2016Guide
Interesting... the icon is grayed out but it still works.
So my issue is that even when I refresh, clear or apply the log, I get the same one daily. It's not clearing the log. To be honest, I havent tracked how long I get them but it could be for 7 days. Each day they are identical
- ElaineMNov 29, 2016NETGEAR Employee Retired
Did you try to reflash the firmware of the router?
If you have the latest firmware, re-upload the latest firmware then do a factory reset then reconfigure the router.
