Darksangle
Apr 30, 2018Follower
r8500 random disconnect while downloading
my router keeps disconnecting from the internet but only while downloading somtimes it even says internet status good but doesnt connect to the inernet i have to re apply the settings or reboot the deivce to get it working.
ive checked its not my pc and its not the modem as ive tried with another router.
this happens on both wifi and ethernet connections and only while downloading but never surfing the net.
firmware version V1.0.2.116
any ideas would be appreciated.
Hi microchip8,
Can you check this firmware.
https://kb.netgear.com/000058809/R7800-Firmware-Version-1-0-2-52
Hi Darksangle,
Try this.
https://kb.netgear.com/000058826/R8500-Firmware-Version-1-0-2-122
- JamesGLNETGEAR Employee Retired
Hi Darksangle,
Have you tried to reset the router to factory default?
- microchip8Master
When you say "while downloading" do you mean maxing out the router's bandwidth or your ISPs line bandwidth?
I had a similar occurance on my R7800 yesterday when downloading at ~480 Mbps. It suddenly stopped and I had no internet connection while the router's GUI says all is fine. After a minute or so, it fixed itself magically. I was too slow to login with telnet and see dmesg output and logs so I don't know what exactly happened. I've downloaded in the past with same speeds mentioned for up to half an hour with not a single interruption
- microchip8Master
OK, I did some further testing on latest V1.0.2.46 firmware for the R7800. I also get consistant same behavior as to what the OP describes
Downloading here at ~480 Mbps cuts off internet after 5-10 minutes and the GUI says it has no WAN connection. I will do some testing on an older firmware and see how it goes
Hi microchip8,
Hi Darksangle,
Try this.
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
