travelton
Nov 19, 2015Aspirant
R8500 Slow Wifi v1.0.0.56_1.0.28
Trying to troubleshoot slow wifi speeds. Anyone experience trouble with the latest firmware update? Speedtest hardwired: Speedtest wireless [2.4Ghz & 5Ghz show about the same speed] (fro...
- Jan 04, 2016
Indeed my router was replaced, however, this didn't solve the problem. A beta firmware ultimately resolved the problem.
netwrks
Nov 19, 2015Master
travelton wrote:Trying to troubleshoot slow wifi speeds. Anyone experience trouble with the latest firmware update?
Speedtest wireless [2.4Ghz & 5Ghz show about the same speed] (from iPhone 6) approximately 3 feet from router:
Wireless Settings:
2.4Ghz - Enabled
WPA2-PSK[AES]
Channel 4
Mode: Up to 1000Mbps
5Ghz - Enabled
Smart Connect - Enabled
WPA2-PSK[AES]
Channel 44 + 153
Mode: Up to 2165 Mbps
Advanced Wireless Settings:
Beamforming: Disabled and Enabled, no difference.
Suggestions for troubleshooting?
2.4ghz, 1,6, or 11. You are creating issues using an overlappong channel for yourself and possibly your neighbours (Channel 4). Try higher channels (150ish) for 5ghz. Ensure WMM is enabled. on the router and your client. If you are running .ac ensure your client has VHT checked.
- traveltonNov 19, 2015Aspirant
netwrks Using a wifi discovery tool, to discover APs in my area, I selected channel 9, as there are no APs broadcasting on that channel. No change in the slow speeds.
I believe this is a software issue on the R8500. I can set up my older Netgear WNDR4500 to broadcast the same 2.4Ghz signal parameters. The WNDR4500 results in consistent 30-40Mbps down, 30-40Mbps up.
