travelton
Nov 19, 2015Aspirant
R8500 Slow Wifi v1.0.0.56_1.0.28
Trying to troubleshoot slow wifi speeds. Anyone experience trouble with the latest firmware update? Speedtest hardwired: Speedtest wireless [2.4Ghz & 5Ghz show about the same speed] (fro...
- Jan 04, 2016
Indeed my router was replaced, however, this didn't solve the problem. A beta firmware ultimately resolved the problem.
ElaineM
Dec 07, 2015NETGEAR Employee Retired
agoetz5201 Do you have the latest firmware installed on the router?
If you do, I suggest that you contact support for further troubleshooting on the speed issue.
ChrisRogers91
Dec 07, 2015Tutor
My speeds were pretty abismal when I was trying to use one ssid. I split everything out (one for 2.4G, two for 5G) and the speeds have been much better.
- ElaineMDec 08, 2015NETGEAR Employee Retired
Thank you for that input ChrisRogers91
Are you saying that SmartConnect is not working properly?If that's the case, I recommend that you contact our support team.
