Omerta51
Oct 31, 2021Follower
R8500
The Nighthawk ax8 8500 power up lights Flash bottom front blue Wi-Fi light goes on but no Wi-fi lights on it in the front and no network shows on any of my devices for it I had it on for 2 days one time had a power outage and it never went back on again it does the same thing I tried resetting it I booted it over and over and over my cousins having the same problem with his if anybody can help me with this thank you
Does pressing the reset button for 10 seconds then release then wire connect a PC to the router and setup the router using a web browser have any effect?
Might try a different power adapter with same volt and amps...
Its only the power light that comes on?
You might have a corrupt firmware.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
